V-series Recommendations
Sets of telecommunications protocols and interfaces defined by CCITT (now ITU-T) Recommendations.
Note: Some of the more common V. -series Recommendations are:V.21: A CCITT Recommendation for modem communications over standard commercially available lines at 300 b/s. This protocol is generally not used in the United States.
V.22bis: A CCITT Recommendation for modem communications over standard commercially available voice-grade channels at 2,400 b/s and below.
V.32: A CCITT Recommendation for modem communications over standard commercially available voice-grade channels at
9. 6 kb/s and below.
V.32bis: A CCITT Recommendation for modem communication over standard commercially available voice-grade channels at
1
4. 4 kb/s and below.
V.34: An ITU-T Recommendation for modem communication over standard commercially available voice-grade channels at
2
8. 8 kb/s and below.
V.42: A CCITT Recommendation for error correction on modem communications.
V.42bis: A CCITT Recommendation for data compression on a modem circuit.
V. FAST: A new CCITT Recommendation for high-speed modems currently under development.
