time-division multiple access (TDMA)
1. A communications technique that uses a common channel (multipoint or broadcast) for communications among multiple users by allocating unique time slots to different users. Note: TDMA is used extensively in satellite systems, local area networks, physical security systems, and combat-net radio systems.
2. A multiple access technique whereby users share a transmission medium by being assigned and using (one at a time) for a limited number of time division multiplexed channels; implies that several transmitters use one channel for sending several bit streams. [47CFR]
