critical frequency
In radio propagation by way of the ionosphere, the limiting frequency at or below which a wave component is reflected by, and above which it penetrates through, an ionospheric layer. 2. At vertical incidence, the limiting frequency at or below which incidence, the wave component is reflected by, and above which it penetrates through, an ionospheric layer. Note: The existence of the critical frequency is the result of electron limitation, i.e., the inadequacy of the existing number of free electrons to support reflection at higher frequencies.
