Coordinated Universal Time (UTC)
Time scale based on the second (SI), as defined and recommended by the CCIR, and maintained by the Bureau International des Poids et Mesures (BIPM). For most practical purposes associated with the Radio Regulations, UTC is equivalent to mean solar time at the prime meridian (0° longitude), formerly expressed in GMT. [NTIA] [RR] Note 1: The maintenance by BIPM includes coordinating inputs from time standards belonging to various national laboratories around the world, which inputs are averaged to create the international time standard (second). Note 2: The full definition of UTC is contained in CCIR Recommendation 460-
4. Note 3: The second was formerly defined in terms of astronomical phenomena. When this practice was abandoned in order to take advantage of atomic resonance phenomena (“atomic time”) to define the second more precisely, it became necessary to make occasional adjustments in the “atomic” time scale to coordinate it with the workaday mean solar time scale, UT-1, which is based on the somewhat irregular rotation of the Earth. Rotational irregularities usually result in a net decrease in the Earth’s average rotational velocity, and ensuing lags of UT-1 with respect to UTC. Note 4: Adjustments to the atomic, i.e., UTC, time scale consist of an occasional addition or deletion of one full second, which is called a leap second. Twice yearly, during the last minute of the day of June 30 and December 31, Universal Time, adjustments may be made to ensure that the accumulated difference between UTC and UT-1 will not exceed
0. 9 s before the next scheduled adjustment. Historically, adjustments, when necessary, have usually consisted of adding an extra second to the UTC time scale in order to allow the rotation of the Earth to “catch up. ” Therefore, the last minute of the UTC time scale, on the day when an adjustment is made, will have 61 seconds. Synonyms World Time, Z Time, Zulu Time.
