closed-loop transfer function
A mathematical expression (algorithm) describing the net result of the effects of a closed (feedback) loop on the input signal to the circuits enclosed by the loop. Note 1: The closed-loop transfer function is measured at the output. Note 2: The output signal waveform can be calculated from the closed-loop transfer function and the input signal waveform.
