chroma keying
In television, nearly instantaneous switching between multiple video signals, based on the state, i.e., phase, of the color (chroma) signal of one, to form a single composite video signal. Note 1: Chroma keying is used to create an overlay effect in the final picture, e.g., to insert a false background, such as a weather map or scenic view, behind the principal subject being photographed. Note 2: The principal subject is photographed against a background having a single color or a relatively narrow range of colors, usually in the blue or green. When the phase of the chroma signal corresponds to the preprogrammed state or states associated with the background color, or range of colors, behind the principal subject, the signal from the alternate, i.e., false, background is inserted in the composite signal and presented at the output. When the phase of the chroma signal deviates from that associated with the background color(s) behind the principal subject, video associated with the principal subject is presented at the output. Synonyms color keying, [loosely] blue-screening, [in security] keying.
