build-out delay
The maximum variable transmission and processing delay that is permitted in a wideband network. Each PVP (packetized voice protocol) node records the delay that it adds and updates accordingly the TS (time stamp) value in the packet header. When the terminating endpoint of a PVP node receives a voice packet, the provisioned build-out and the time stamp value are compared. If the TS value is larger than the build-out, the PVP node drops the packet. If the delay is less than the provisioned build-out, the packet is delayed by the difference between the two values. [T1.312-1991]
