block-error ratio
1. The ratio of the number of incorrectly received blocks to the total number of blocks transferred. Note: The block-error ratio is calculated using empirical measurements. Multiple block-error ratios may be used to predict block-error probability.
2. The ratio of the number of blocks that contain at least one bit in error to the total number of blocks transmitted in a given time interval. [T1.501-1988]
