bit synchronous operation
Operation in which data circuit terminating equipment (DCE), data terminal equipment (DTE), and transmitting circuits are all operated in bit synchronism with a clock. Note 1: In bit synchronous operation, clock timing is usually delivered at twice the modulation rate, and one bit is transmitted or received during each clock cycle. Note 2: Bit synchronous operation is sometimes erroneously referred to as digital synchronization.
