bit-stream transmission
1. In bit-oriented systems, the transmission of bit strings.
2. In character-oriented systems, the transmission of bit streams that represent characters.
Note: In bit-stream transmission, the bits usually occur at fixed time intervals, start and stop signals are not used, and the bit patterns follow each other in sequence without interruption.
