bit interleaved parity N (BIP-N)
A method of error monitoring. If even parity is used, an N bit code is generated by the transmitting equipment over a specified portion of the signal in such a manner that the first bit of the code provides even parity over the first bit of all N-bit sequences in the covered portion of the signal, the second bit provides even parity over the second bits of all N-bit sequences within the specified portion, and so on. Even parity is generated by setting the BIP-N bits so that there are an even number of 1s in each of all N-bit sequences including the BIP-N. [T1.105-1988]
